I have an 84 E30 Coupe which was automatic. I'm fittin an M60 and manual box and trying to sort out the gear shift.
I have the later design parts from a Z3 including the alloy shifter mounting arm from the box and the linkage, gearstick etc, but looking at Realoem, the early model cars seemed to mount the shifter on the tunnel
http://www.realoem.com/bmw/enUS/show...diagId=25_0091
I understand that with the M60, both linkage arms will need to be modified, but can the later design be used? It means both pivots move with the engine and box which should prevent the gearknob wagging around.
Finally, when going from auto to manual, is there a suitable spot for the rear support bracket for the alloy arm to be installed (part 8)?
http://www.realoem.com/bmw/enUS/show...diagId=25_0066
Thanks
Thanks
