4.6 modular swap
  • peerless
    • 285
    #61
    I was tooling around doing some 5.0 research and I came across this 4.6 Ford with a roots blower mounted up in a rod running megasquirt.
    Its just a start up video but pretty cool to see. Figured you might be interested.
    Going to the junkyard this weekend. Hope to find a engine and trans myself.
    Look forward to the next update.
    • Mako18
      • Jul 2006
      • 688
      #62
      Originally posted by peerless
      damn, this is a great project. I am planning a 5.0 swap and am on the hunt for parts.
      I am very interested in how you mounted the engine. Also whats your oil pan solution?
      Nothing.
      +1
      • Spinning Tires
        • Feb 2007
        • 283
        #63
        Damn, this is a great project. I am planning a 5.0 swap and am on the hunt for parts.
        One guy did a 5.0 swap on bfc a couple years back but provided zero documentation, no videos, nothing.
        My 5.0 swap is more as a tool to create a conversion kit for the masses so it will retain the stock E30 suspension. Only needs a custom driveshaft.
        Your obviously going for a full drag race setup. Very impressed with your work and engine choice.
        I will keep an eye on this thread.
        I was putting a chevy 350 in an e30 i had. the t-5 shifter lined up with the shifter hole perfectly. I had to hammer the shit out of the firewall. Your gonna need a hydrolic throwout bearing because the clutch fork where the cable hooks up will end up being where the gas pedal is in the car. Also I used a universal crossmember from summit for the motor and i made my own trans crossmember which i'll sell if you want it. heres the link to the crossmember from summit i dunno if they make one for a 302.
        http://store.summitracing.com/partdetail.asp?autofilter=1∂=TRD-4840&N=700+115&autoview=sku
        also i was going to use the hydrobooste from a 5 series to clear the valve cover. I can keep going. PM if you want more info i found out
        First: 1984 318i
        Second: 1987 325
        Third: 1987 325is
        Current: 1990 325i (Soon To Be 335i)
        • rneedham1979
          • Jul 2008
          • 852
          #64
          wow
          Turbo E30
          Roadkill 80lb 93 octane OBDI tune
          BavSol Cylinder Head
          Stock S50 in. cam Schrick ex. cam
          Otis' tubular T4 manifold
          Oringed 87mm S52, Eagle rods and 8.5:1 CP pistons.
          GT4094r w/Batmowheel Impeller
          614whp@17.5psi, 100 Oct
          690whp@21psi, 100 Oct
          801whp@27psi, 110 URT
          Old: 1/4 mile: 10.91@144.38 (636whp)
          New: ?
          http://www.youtube.com/watch?v=L_f7fUVqblI
          • christoble
            • Sep 2005
            • 222
            #65
            I got most of the cage done and I started on the sheet metal. I took a few pics with my phone. I will take more later
            Parts for sale http://www.r3vlimited.com/board/showthread.php?t=128440
            Car for sale http://www.r3vlimited.com/board/showthread.php?t=118679
            • christoble
              • Sep 2005
              • 222
              #66
              • Cobra Jet
                • Apr 2008
                • 278
                #67
                schweeeet.... gonna watch this thread for sure...
                Just one small suggestion - pull that little 4.6 out and go for a 2003/04 Cobra Terminator engine setup... :nice:
                What are you using up front for the motor mounts and steering/suspension assembly - are you also using a Mustang K-member and associated A-arms, springs, etc?
                • alpinaclone
                  • 820
                  #68
                  subscribed
                  Matt
                  • bimmer630
                    • 1228
                    #69
                    Wow..lotsa work.. why not just put that engine in a, um... Mustang?
                    • Flash
                      • 688
                      #70
                      Look good so far (i didnt get past the first page), great to see another enthusiast taking it a step further :)
                      Are block hugger headers available to clear the steering rack?
                      • Cobra Jet
                        • Apr 2008
                        • 278
                        #71
                        any updates?
                        • nickpdx
                          • 679
                          #72
                          I'm not usually a big fan of big V8 e30 engine swaps, but this looks like a cool project. My dad has owned two Ford Explorers with the 4.6 modular, including the 3 valve one you're using...it's a good engine and even in an SUV like that is pretty quick. I think the Explorer can beat my e30 to 60. :(
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            #73
                            Bump?
                            • F34R
                              sLaughter
                              • 12376
                              #74
                              WOW! Subed!
                              Instagram: @BWeissLeather
                              Current cars:
                              ~ '87 325 M30B35 swap
                              ~ '87 535
                              ~ 01 540 Msport 6spd
                              ~ '06 X5 4.8is
                              • KennyT
                                • 542
                                #75
                                Interesting..Subbed.
