Ethurtee and Iliad's S62 Mtech 2 Build
  • iliad
    • 474
    Hello everyone!
    Although we are not the first to do this swap, I figured we would still go ahead and do a build thread to document our process.
    The car was purchased off of Craigslist here in New Orleans around 4 years ago as a bone stock 1989 325i with a cloth interior and a manual trans.
    Our intentions for the car were not known at the time, we just knew this was a super clean chassis and a great start to any project.
    First things first, we gave the car a good cleaning.
    Pics of how it started (Actually at this point we refreshed the suspension with some H&R drop springs/Billie Sports, + control arms etc.
    Followed by a timing belt, water pump, belts and a refresh of all the hoses.
    2020-03-31_12-14-13 by Brian Hardy, on Flickr
    2020-03-31_12-17-10 by Brian Hardy, on Flickr
    Next up, the unsightly cracked dash had to go and while we were at it, we refreshed the ODO gears, installed a euro clock, swapped out the wheel and threw in some cardinal sport seats :)
    2020-03-31_12-23-02 by Brian Hardy, on Flickr
    2020-03-31_12-23-18 by Brian Hardy, on Flickr
    2020-03-31_12-24-23 by Brian Hardy, on Flickr
    Fast forward about 4 months and Voila, we have a freshly painted OE Mtech 2 kit begging to be installed.
    The first two pics show the current state of the car before the MTech install. In the 4 months time she received a set of MHW tails, French Smileys and a set of 16" Futuras!
    Onto the pics!
    20170527_130833 by Brian Hardy, on Flickr
    20170527_130846 by Brian Hardy, on Flickr
    Mtech 2 goodness just picked up from the painter!
    20170527_100649 by Brian Hardy, on Flickr
    New valence as well since the old one was pretty beat up. Plus French fogs to match the headlights.
    20170527_174103 by Brian Hardy, on Flickr
    20170527_143110 by Brian Hardy, on Flickr
    lots of drilling and little brackets.
    20170527_185041 by Brian Hardy, on Flickr
    Front is done!
    20170527_210858 by Brian Hardy, on Flickr
    Time for the rear.
    20170527_221334 by Brian Hardy, on Flickr
    spoiler installed
    20170527_231534 by Brian Hardy, on Flickr
    Rear end is done!
    20170529_112409 by Brian Hardy, on Flickr
    Side skirts and pods next.
    20170529_161506 by Brian Hardy, on Flickr
    With proper sills!
    20170529_161211 by Brian Hardy, on Flickr
    All done!
    What a transformation!
    20170603_094841 by Brian Hardy, on Flickr
    20170603_094940 by Brian Hardy, on Flickr
    Sitting pretty at our local C&C with good company!
    IMG_20180220_135228_004 by Brian Hardy, on Flickr
  • rzerob
    • Jun 2013
    • 2315
    I see you fixed your pictures so I deleted my post. Subscribed.
    • iliad
      • 474
      At this point you may be asking where is the S62!??
      And here she is..
      Some of you may remember this car posted for a sale a while back (maybe 2-3 years ago). It contained a lot of what we wanted to do the swap how we envisioned and we were able to sell of all of the bits that we didn't need to help offset some costs.
      The day the tow truck dropped her off:
      2020-03-31_12-31-54 by Brian Hardy, on Flickr
      The carnage was pretty serious
      20170712_212519 by Brian Hardy, on Flickr
      It took a lot of cutting and prying to free up the S62
      20170713_183728 by Brian Hardy, on Flickr
      After assessing the damage, which comprised of a busted upper and lower oil pan, some broken pulleys, oil lines and some other smaller miscellaneous parts, the first order of business was new rod bearings.
      WPC treated bearings were ordered with new bolts, new lower oil pan (the upper one was repaired), and the bottom end was resealed.
      Drew, excited!
      20170729_174319 by Brian Hardy, on Flickr
      Obligatory bearing photo
      20170730_100234 by Brian Hardy, on Flickr
      Resealed with new pan
      20170730_133928 by Brian Hardy, on Flickr
      At this point, life got in the way and the project took a back seat.
      The parts car was stripped and parts were stored.
      Fast forward another 4 months or so and we are now creeping up on The Vintage.
      The plan was to take the white e30 and Drew drive the S38 swapped e30 which we just finished freshening up with an Mtech 1 kit. Unfortunately we ran out of time and could not get the car to cool well enough (with AC on) to make the 1500 mile trip from New Orleans to Ashville NC.
      There is always next year!
      2020-03-31_01-42-58 by Brian Hardy, on Flickr
      This meant the black car was going to make the trip instead,
      5 of us from the NOLA Bimmers car club in 4 cars hit the road and made it to Ashville without issue!
      2020-03-31_01-44-34 by Brian Hardy, on Flickr
      2020-03-31_01-46-08 by Brian Hardy, on Flickr
      2020-03-31_01-46-32 by Brian Hardy, on Flickr
      If you've never attended The Vintage, I highly recommend it to any enthusiast. Since we found out about it just 3 years ago, we have not missed a year!
      Hundreds and hundreds of the coolest cars and enthusiasts surrounded by killer roads and beautiful scenery!
      2020-03-31_02-23-42 by Brian Hardy, on Flickr
      2020-03-31_02-24-12 by Brian Hardy, on Flickr
      2020-03-31_02-24-47 by Brian Hardy, on Flickr
      2020-03-31_02-24-27 by Brian Hardy, on Flickr
      Shortly after returning from our trip the swap officially began!
      out with old faithful M20, she lives on in an e30 Lemons race car.
      2020-03-31_01-47-15 by Brian Hardy, on Flickr
      2020-03-31_01-47-43 by Brian Hardy, on Flickr
      • The Dark Side of Will
        • Jun 2010
        • 2796
        Where'd you get your bearings?
        • iliad
          • 474
          They were sourced through ECS.
          • Mike36
            • 1079
            Sub'ed! Ever considered shadowlining the window trim on the black mtech?
            • ethurtee
              • Jan 2013
              • 1991
              One of these days. We sourced a set from a318iS, but a buddy of mine bought the car and wanted it back.
              • Mike36
                • 1079
                Remove your own set and have them powdercoated semi gloss black. Comes out looking OEM.
                • ethurtee
                  • Jan 2013
                  • 1991
                  That's the plan, eventually. There are a couple of paint issues that need to be addressed, so it'll get done when it goes back to the painter. Before a few weeks ago, this car hadn't seen the ground in a couple years, and I doubt I put 3000 miles on it since we got it (most of which were driving to/from the Vintage). I'll worry about the finishing touches once the swap's buttoned up.
                  • iliad
                    • 474
                    Alright, first order of business was to tackle the remote booster setup. We want this car to drive as stock as it did before the swap so boosted brakes were a must.
                    Factory air box brackets removed and area cleaned up.
                    20180916_121803 by Brian Hardy, on Flickr
                    Booster roughly placed where it will go. The master cylinder will sit between the headlights and the MK60 ABS system will be fitted as well to improve the braking and also give us a little more room.
                    20180916_140053 by Brian Hardy, on Flickr
                    300MM s62 swap kit has arrived! Everything looks to be super nice quality!
                    2020-03-31_02-50-52 by Brian Hardy, on Flickr
                    Engine dropped in so that we can make sure we don't have any interference with the booster setup.
                    20190622_193826 by Brian Hardy, on Flickr
                    Pedal bracket removed and modified
                    20190622_171300 by Brian Hardy, on Flickr
                    Bracket made up using the old coolant tank mounting point
                    2020-03-31_02-59-03 by Brian Hardy, on Flickr
                    AC compressor mounted up and it's immediately apparent that the frame will need some modification for it to work.
                    20200112_133404 by Brian Hardy, on Flickr
                    20200112_133423 by Brian Hardy, on Flickr
                    With the engine back out of the car, we decided to tackle the Vanos units and do a top end reseal with new plugs and all.
                    20180930_160123 by Brian Hardy, on Flickr
                    20180930_161007 by Brian Hardy, on Flickr
                    20180930_174039 by Brian Hardy, on Flickr
                    20180930_180121 by Brian Hardy, on Flickr
                    In the middle of this build, the weekend warrior with a 200k mile s54 swap decided it didn't want to put out anymore. Here is a photo of it getting a fresh s54.
                    2020-03-31_02-40-04 by Brian Hardy, on Flickr
                    • Zacm829
                      • Jan 2008
                      • 1919
                      Great work so far. You will be glad you are going with power brakes, worth the effort on my v8 swap. Keep up the progress!
                      1987 325i-M60b44 swap
                      • iliad
                        • 474
                        Thanks, we are super excited!
                        That was our thought as well. We want it to stop as well as it goes!
                        • iliad
                          • 474
                          Another update as we push through this project!
                          Engine pulled once again to make the final modifications for the brakes and the AC system.
                          MK60 ABS unit location finalized and lines made up.
                          2020-03-31_03-15-19 by Brian Hardy, on Flickr
                          Booster stripped and repainted
                          20200202_114806 by Brian Hardy, on Flickr
                          Cleaned up the booster bracket as well
                          20200202_114745 by Brian Hardy, on Flickr
                          Booster mounted up for the last time
                          20200209_104338 by Brian Hardy, on Flickr
                          Z3 rack installed with a sikki steering shaft (really nice piece),new master, lines..
                          2020-03-31_03-23-44 by Brian Hardy, on Flickr
                          Frame rail modification begins for AC compressor clearance.
                          20200202_141717 by Brian Hardy, on Flickr
                          2020-03-31_03-24-42 by Brian Hardy, on Flickr
                          Started shaping the new metal. We wanted to retain the upper lip and make it look as original as possible.
                          20200223_170316 by Brian Hardy, on Flickr
                          20200223_170330 by Brian Hardy, on Flickr
                          all welded up
                          2020-03-31_03-26-27 by Brian Hardy, on Flickr
                          20200223_203917 by Brian Hardy, on Flickr
                          engine back in to check clearance, perfect!
                          20200229_170522 by Brian Hardy, on Flickr
                          Tight on the driver's side but that's been the MO of this swap!
                          20200229_170532 by Brian Hardy, on Flickr
                          Cleaned up the area that was welded up
                          20200307_094428 by Brian Hardy, on Flickr
                          Base coat
                          2020-03-31_03-36-23 by Brian Hardy, on Flickr
                          Clear coat
                          2020-03-31_03-37-21 by Brian Hardy, on Flickr
                          • dmjensen
                            • Jan 2011
                            • 804
                            Awesome progress dude! What’s your plan for running the Mk60 ABS?
                            • iliad
                              • 474
                              I did the same setup on my weekend track warrior and love it, so it made sense to do the same on this car especially since we were already going to relocate the abs pump.
                              The mk60 unit actually saved us some space as well, so win win!
