How to remove chrome trim on door?
  • mike87
    • 300
    Does anyone know how to remove the chrome trim on the door that holds the exterior window seal against the window? This long piece of chrome trim just above the red line in this photo marked as 'B'.
    Thanks!
  • tomstin
    • Mar 2015
    • 569
    I replaced the rubber weather strip the seals the glass a few months ago. As I recall, you carefully pry that piece up. Maybe this drawing will help
    https://www.realoem.com/bmw/enUS/sho...diagId=41_0948
    2004 525i Manual - 1985 325E Coupe Manual
    • Codym42
      • Mar 2013
      • 611
      Both the seal and the chrome strip pry up out of clips on the top of the door. Its probably best to use some plastic trim removal tools to get the chrome trim off. Be careful so you don't bend it.
      '90 325i - 5 speed coupe
      '05 330ci 6MT ZHP
