euro 323i timing belt: and water pump?
  • 2002jm
    • Sep 2005
    • 2076
    I am changing the timing belt and pump on my1985 323i euro. I can only find a timing belt for the 2.5l 1985 USA car. Is that a problem, or do I need to sell my kit and buy one from the dealer for an 1985 323i euro?
    thanks for any help,
    jm
  • ADEN
    • 620
    The only diffrence is the water pump check the one on your car with the one you bought i think m20 has 2 types one has 2 inlets for hoses the other is only 1 inlet.
    • roguetoaster
      Biggus Tippus
      • 7830
      Timing belt/tensioner lists as the same for all M20 engines. You probably have 11519071562 for a water pump, if you have two outlets on the neck off of the pump.
      • 2002jm
        • Sep 2005
        • 2076
        ok, thanks; will check in the morning. thanks for the replies,
        jm
