1987 Auxiliary fan Fuse #3 keeps blowing out
  • slippery
    • Nov 2011
    • 378
    I have a 1987 that all of a sudden started running hot when stopped. I traced it to a non running aux fan, and when I jumped the wires at the radiator switch it came to life but it was quite noisy.
    I ordered a new fan from ECS, and swapped it and then found the #3 fuse to be blown. I replaced the fuse thinking that the old fan bearings were causing high amp draw and the fuse blew up in a second after turning the car on.
    I am not very good with electrical systems, and I assume this is caused by a short somewhere. Can anyway help me or point me in the right direction in order to figure this out? I have a test light and also a voltmeter.
    Thank you.
  • tomstin
    • Mar 2015
    • 569
    First, find your wiring diagram here: http://wedophones.com/Manuals/BMW/
    (on my 85) In the Auxiliary Fan page, Fuse 3 is between the K1 Normal Speed Relay and the Normal Speed Blower Resister (mounted on a bracket in front of the fan). My guess is that resister is shorted or the wiring is messed up as the new fan should not blow a 15 amp fuse.
    2004 525i Manual - 1985 325E Coupe Manual
    • slippery
      • Nov 2011
      • 378
      Thanks for the reply.
      I do have the wiring diagram but I had no idea where to start.
      The new fan came with a new resistor, but I will remove the grill and see what I find.
