Windows, sunroof, heater fan and who knows what else stopped working on my 88 M3
  • Del Schier
    • May 2022
    • 6
    Also, maybe unrelated, the tach started jumping all over the place, or not reading at all, or working.
    It appears that this may be a ground issue as these are all separate circuits. One guy on YouTube fixed his E30 by moving a wire on his starter solenoid. I would like to know why he moved the ground wire a different terminal, but his video may be a clue. It appears that the starter has a separate ground terminal, so I would like to see a diagram of what is inside the solenoid. I think it disconnects accessory circuits to protect from the back EMF of the starter motor.
    I just got done with major service and got it back on the road. Everything was working on the beginning of a test ride but, I think, it quit on the last re-starting.
    If so, it looks like a major hassle to get at the starter. It can't be seen from the underside and barely visible under the intake plenum after taking off the FI flow sensor. Any info, or tips of any kind would be appreciated.
  • Del Schier
    • May 2022
    • 6
    It started working again after I took out unloader relay K7 and cycled and tested it on the bench. I will clean and tighten the starter connections and if it happens again replace K7. I'll keep you all posted.
    • mr_zvirgzdins
      • Mar 2015
      • 4
      Im having the same issue. Cant find a solution and too dumb to do electrical testing 😀 Blower works when directly wired, also works when completing the circuit where the k7 relay connects in the fuse box. Blower motor is not getting power at all.
      Sent from my POCO F2 Pro using Tapatalk
