What type of grease for sunroof???
  • BrewCity11
    • Mar 2008
    • 2335
    I forgot to look in my Bentley, and want to buy some grease on the way home.
    I cleaned up the sunroof tray area and as much of the tracks as i could.
    Wondering what's the best/recommended grease for it.
    Thanks alot!
    (searched, but nothing cam up as far as what type of grease)
    turk@gutenparts.com
  • Liam
    • 753
    Well, it's best no to use any on the tracks because it attracts grit.
    Just keep it clean and use a silicone spray.
    On the cables and drive gears (if you dig in that far) I would use "cam" grease (AKA distributor grease)
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
    • BrewCity11
      • Mar 2008
      • 2335
      White lithium grease OK?
      Thanks, btw
      After some google searches, came up with Wurth HHS2000 as the best stuff. I'll see if i can find some at a parts store on the way home tonight.
      turk@gutenparts.com
