Rear axle torque specs 1989 325i
  • Mason
    • Aug 2022
    • 16
    I have seen a couple different numbers in reference to torque specs for the rear axle nut so I was hoping I could get a response to be sure. I'm also wondering what the torque spec is for the axle to differential bolts.
    Any help would be much appreciated, thank you.
  • mtech325
    • May 2008
    • 568
    According to the Bentley manual:
    rear axle nut: 144-155 ft. lb
    inner CV joint internal hex bolts: 42-46 ft. lb
    Here's another link with the torque values listed as well: https://www.rtsauto.com/e30-torque-s...pecifications/
    • Mason
      • Aug 2022
      • 16
      Thanks I was reading some other post saying the nut was 180ft. lbs so I'm glad I could clear that up.
      Thank you again 🙌
