Square c101 Pinout question
  • Dawskip
    • Feb 2018
    • 242
    So from what ive been reading, this is the pin out for a square model
    EARLY / SQUARE:
    Pin Colour Function To
    1 Blue Charge light pin 16 blue plug inst cluster
    2 Green/Yellow Static oil level Pin 16 check panel
    3
    4 Brown Temp gauge pin 26 blue plug inst cluster
    5
    6 Green/White Oxygen sensor relay Fuse 9
    7 Green/Purple fuel pump relay fuse 11
    8 White/Black Start Ignition Switch
    9
    10 Live power from ignition unfused
    11
    12
    13
    14
    15 Black/Green Unloader relay pin 1 blue plug inst cluster
    16 Brown/Green Oil Pressure light pin 18 blue plug inst cluster
    17 White/Green Reset service lights pin 22 blue plug inst cluster
    18
    19​
    Late model (circular) have a static and a dynamic oil level pin, from what I see, there is only a static in my harness.
    How would I go about wiring in a dynamic for my swap?
