When my 1984 bmw 325e is cold (first start of the day) the car idles perfect for about 10 seconds then gradually but everytime starts to run richer and richer until it bogs down completely and dies. If you give it more throttle itll keep it alive but even after a couple minutes itll still want to die, you have to drive it for a little to warm it up to have it idle normally(take this with a grain of salt "normally" is just being able to keep idle).
I have refreshed the fuel injectors (might take another look at them again),
Done a smoke test and fixed the two leaks there was (AFM box, loose hose in the intake boot),
Replaced the fuel pump(in line) and 1 fuel filter (closest to the pump),
Replaced the FPR (accidentally bought a 3.0 bar one I have a 2.5 bar that I might test),
Replaced the Coolant Temp Sensor (blue switch closest to the intake manifold)
Have the Thermo time switch and the Sensor for the cluster temp gauge coming for good measure
+The previous owner swapped to an aftermarket thermo time switch and horrible wiring so going to fix that back to factory
+The previous owner did his own wiring to the sensor for the cluster temp gauge (the ground wire came out of his crimp too)
Re did the connector for the ICV (was loose and corroded a little) (clicks when connecting wiring with the car in accessory)
+Cleaned out the ICV a while back
AFM has been opened by the previous owner - if i remember correctly it was all the way to the left. I have since resealed it due to air getting out of the sensor
I have tested the idle control module by swapping it with another one to try and see if there was a difference - no change in idle still bogs down
I did lose the cap to the barometer
I tested the brown switch (farthest from the intake) and there was no reading when cold - couldnt find what sensor that was or if it was suppose to read something
I have a spare cap and rotor I can try
I took off the cold start injector and its not leaking any fuel, and when unplugging makes starting the car a little harder but has same symptoms with it unplugged.
I do believe the car needs a valve adjustment there is a good amount of valvetrain noise coming from the top end, could be one of the reasons mayber?
I have tried a lot of things probably not listed on this list but I am grasping at straws at this point and can use any help from someone that could give some advice
