1: Is the 9.0:1 compression ratio too high for a low boost turbo? Something in the range of 5 psi with no more than 7.5. I want to use stock internals and basically make this thing look and work like it came factory installed.
2: How is everyone finishing their valve covers? I have tried twice now and i still havent gotten it right. I sprayed the whole thing, let the paint dry, cure, and then proceeded to sand the ridges down with a sanding block. Looks like the best way to do it is mask all around so the sandpaper doesnt interfere with the paint and breather opening (i had this problem). But how do you get in the really tight spots? for instance the three small ridges on the other side of the ICV plate.
I appreciate any help. Thanks,
jon
jon
