Interesting observation about Redline MTL
  • kencopperwheat
    King of Kegstands
    • 14396
    Copied from unofficialbmw.com
    I thought it was pretty interesting because I'm having the same problem.
    7.6.1: Redline MTL
    (NOTE: While most digesters really swear by MTL (Manual Trans Lube)
    to improve shifter smoothness, especially in cold weather, there may
    be a problem. This has since been reported by several other
    digesters:)
    Date: Mon, 10 Apr 1995 08:39:43 -0400
    Dear netters;
    Dewspite all the wonderful things about MTL, I've one question...
    I've been experiencing repeated failure of the backup light switch in an
    '82 528E. The backup light bulbs are standard P25-1 (equiv. 1156). A new
    switch lasts for maybe one month.
    At first I attributed the failure to a bad batch of inferior aftermarket
    switches. But repeated failure with switches from different sources,
    including BMW OE parts, suggest re-evaluation.
    (Destructive) disassembly of failed switches reveals normal slight
    discoloration of the contact, but no pitting, etc. Minimal cleaning
    restores low contact resistance, but the switch cannot be reassembled. :(
    Is it possible that the Redline MTL in the gearbox is creating a
    sufficiently non-conductive film that it permeates the rubber membrane,
    coats the contact, and creates the failure? Has anyone else, using MTL or
    not, experienced this?
    Please reply directly, as I get only about 1 of 3 digests on average. I'll
    summarize responses for the list. Thanks!
    - -Paul Reitz, BMW CCA #1167
    (prreitz@amp.com)
    [2002, 733, 528e, 325iX]
    Originally posted by Gruelius
  • Rich V
    • Oct 2004
    • 69
    Ran the stuff in both my E30's and never had a problem. One for one year and the other for 3 years.
    • Jand3rson
      • 37587
      That sounds pretty flimsy.
      • mspiegle
        • 1026
        is the switch inside the gearbox?
        Michael Spiegle
        '01 Ford Escape / Daily Driver
        '99 M3 / Track Car
        '87 325is bronzit / wtf car
        '06 Daytona Triumph 675 / Daily Rider
        • rs4pro3
          • 5808
          Now it screws into the side, I put Redline in my 88 the switch never worked so I replaced it and a week latter it went out(put in a used switch) every once and a while the switch will kick on though.
          85 325e 2.7 ITB'd stroker
          • Giorgio
            • 169
            my switch went out on my old 89 325i, i learned the lesson of fixing your reverse switch the hard way unfortunately, the car hasn't had redline for couple years, i'm running some standard valvoline, but that is interesting, i will fill you in if the switch goes bad again w/out redline.
