clutch question
  • MGB GT
    • May 2008
    • 37
    clutch question
    The clutch in my 89 325I is engaging right at the top. All I have to is depress the pedel less than 1/2 inch to engage it. It isn't slipping or any other problem. I'm just wondering if this is the begining of the end of the clutch?
    Thanks,
    Tom
  • Liam
    • 753
    It is pretty normal for the engage to be high, this is one of those things I'd have to "feel" to tell you.
    If it holds and doesn't chatter or cause shift engaging problems you're probably fine.
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
