New Motor wont start
  • BlackE30
    • Sep 2004
    • 605
    I just completed my engine swap, I just installed a new m20b25 rebuilt motor.
    the motor is cranking, All sensors are in, But the alarm that hasnt worked in years seems to be going off. all of the lights are flashing. I need to disengage it. Help!
    • 37833
    Ripping the alarm out would be a good start...
    Grover Beach, California
    BimmerHeads.com
    • BlackE30
      • Sep 2004
      • 605
      well my friends dad came over, he owns a alarm installation/ audio place. He says its not my alarm thats causing the motor to not run. I checked my motor and I am getting spark. I am also getting fuel up to the fuel pressure regulator. The motor is turning over but its just not startin up.
      • kencopperwheat
        King of Kegstands
        • 14396
        Are the injectors spraying? What about your Cold Start Valve?
        Originally posted by Gruelius
        • James Crivellone
          Head Janitor
          • 6305
          make sure all those sensors are connected, check all the wires, make sure everything is correct
          • Jordan
            • 12916
            Make sure your crank position sensor and ignition wire refference sensor connectors arent swapped (under the diagnostic port)
            https://mtechniqueabs.com/
            • E30godz
              • 1524
              yea when i just recenetly put the rebuilt head on my car, that happened to us.
              • BlackE30
                • Sep 2004
                • 605
                where is the cold start valve located?
                I am gonna go out and check the crank positions sensor ignition wire refference are correct.
                • Jordan
                  • 12916
                  You haven't got one.
                  • BlackE30
                    • Sep 2004
                    • 605
                    ohh, alright going to go look at those sensors
                    • BlackE30
                      • Sep 2004
                      • 605
                      this is a dumb question but where is the diagnostics port located?
                      • BlackE30
                        • Sep 2004
                        • 605
                        I found it, bout to switch
                        • BlackE30
                          • Sep 2004
                          • 605
                          It didnt do anything, still turning over but not starting up.
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            Are you getting fuel firing out of your injectors?
                            • BlackE30
                              • Sep 2004
                              • 605
                              well I figured out that my brother reversed the fuel lines. I switched them back and got the motor to run! but the starter seems to be running with the car as it idles which doesnt sound good. :?:
