My cluster - VDO or Motometer?
    How can I tell whether I have a VDO or Motometer cluster? The odometer gear supplier is asking, and I have no idea. Car is a 1988 325i, US-spec.
    Thanks!
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
    Thanks!
    Should be noted on the front of it between the tach and odometer.
      here is a pic i found for ya
      if you have a vdo it will say between the speedo and tach and the same if you have a motometer.
      also a vdo will have a white sticker on the back of the cluster if you have it out of the car.
      Project
      Parts for Sale
      Feedback
      YouTube Channel
        Yep it says right on the front, but I believe the gears are the same.
        If you don't mind me asking where are you getting the gears?
          Well, that made it easy! VDO it is. Thanks!
          -Dr. Paul Forrester
            yep
            you asked a simple question. you did not need a answer
            Hope that helps
            where are you getting your gears from?
            Project
            Parts for Sale
            Feedback
            YouTube Channel
