Stupid mistake, big problem, need help.
  • robbieosterman
    • May 2004
    • 199
  • Charlie
    kid tested, administrator approved
    • 6686
    Invest in a set of Weber Carbs.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • UNHCLL
      • 8790
      part it out
      or buy a new wiring harness. likely most fuses and relays are blown.
      Below the radar...
      • Jordan
        • 12916
        You blew the fusable link at very least. Replace it and try to start again. Chances are that is all you fried. You very likely may have fried the alternator, and ABS computer as well. Perhaps more.
        https://mtechniqueabs.com/
        • robbieosterman
          • May 2004
          • 199
          Alright, thanks Jordan. Where is the fusable link?
          • Rob
            • 8166
            +=red
            BEERTECH
            • atmh
              • Sep 2004
              • 165
              Don't forget the positive terminal is also larger.
              I am no expert on the subject, but shouldn't there be enough failsafes that it wouldn't destroy components in his car? I would think it would just blow pretty much every fuse/relay. I remeber hooking a battery up wrong once...everything got warm...FAST.
              • 85-318i
                • Nov 2004
                • 5
                did you change to a new battery?
                That one will be toast!
                :shock:
                • BahnE30
                  • 1050
                  it's the alternator it's toast
                  when the car looses voltage in general the light comes on..... if the alternator was good it wouldn't come on while the car is running, everything runs or the alternator once the car is started, battary is only there to start the car plus misc lights when it's not running. ie. open doors and such.
                  • 85-318i
                    • Nov 2004
                    • 5
                    Batt's done
                    Alt maybe
