Any one have a picture of the sheet metal shifter mounts?
  • rs4pro3
    • 5808
    Hi guys I need a picture of the rear Mount on the Sheet metal shifter consule? Any one have one? I Ordered all new brackets, and mounts. But can't figure how they fit together(been a while since I worked on the 318i)
    85 325e 2.7 ITB'd stroker
  • arnoldgtr
    • Mar 2004
    • 153
    Ely,
    I don't think my 318i has the top bracket, #5. The console rests on the rubber mount, which then rests on the bottom bracket, #6. On my car, the bottom bracket has the threaded stud which attaches to the body of the car.
    Here is the ETK illustration:
    John
    88 ///M3 Cinnabar
    84 318i Black
    • rs4pro3
      • 5808
      I purchased both the bottom, top, and the rubber mount brand new at the dealer. But could't figure out how #5 rsts on the consule, and if the mount is pulled tight threw the consule, or just set loosely in the hole.
      I believe my 318i was the same way also with only the #6 bracket but the one I ordered looks different from what I remember. To bad I don't have either of my 318i's to get under and take a look.
      I've got the shifter all rebuilt with a M-coupe lever, just trying to figure out that rear. When Put together how I think it should be the rubber Mount barely contacts the lower mount, and is allowed to move around.
      • Bill 84 318i
        • 1600
        I was just as confused as you when I first got all my parts.
        #5 isn't even used - I don't know why it's in the diagram. I went to the parts dept and he clarified it with a tech.
        Take that rubber piece (#7) and pull it through the hole in #6 and through the hole in the shift console. Pull it all the way through (there's a little ridge in the rubber for the solid pieces to "click" into. That's all there is to the rear.
        • rs4pro3
          • 5808
          Ok cool, that's what I thought, any one want a Brand new Lower Bracket?
