Terrible Idle.
  • 88e30is
    • Feb 2007
    • 690
    Terrible Idle.
    For a while now my car has been idleing like it has a crazy cam in it. I pulled the AFM out and cleaned it, reinstalled it and then it ran perfect for a few weeks. Last week it started doing the same thing and now it will stall after I start it sometimes. Its getting to be a big annoyance and I would like it fixed. Does this sound like the AFM?
    That could be any of a number of things, but the first thing to do would be to eliminate any possibility of intake leaks. Then verify proper fuel pressure and delivery.
    • 88e30is
      • Feb 2007
      • 690
      I'm almost positive I have gotten all the intake leaks taken care of and I am getting plenty of fuel because I can smell it. Would a bad AFM make it run rich?
      • Adrian_Visser
        • Jun 2006
        • 2823
        so it is missing at idle and you can smell fuel in the exhaust? Is it when the engine is cold or warm that you have a problem? if it is running rich and idling badly when warm your coolant temp sensor could be bad, a bad afm could cause this too i suppose
        The engine runs smoothly at speeds other than idle right?
        '89 Alpine S52 with goodies
        • 88e30is
          • Feb 2007
          • 690
          OK, I took a better look at the intake boot and pulled it off. Thats definitely the problem. I just used some electrical tape and sealed it good, reinstalled and its good to go (temporarily). Now I just need to buy a new boot.
