Well, the Haynes manual does it again. (did a search, no luck) My good ole manual says all i need to do it take off all the bolts and pull the pan off. Well, it doesnt work that way on the e30. Basically it wont come off because it is hitting the oil pump and the rack wont let it drop down far enough. Whos done it, how do I do it? There is nothing left of my old gasket, pieces are falling down into the pan and i need to get it out and clean the entire thing and put my new gasket on. tia.
oil pan removal
there's the bentley manual version, just took a pic for ya. -
yah when my oil pan was in peices i tried as hard as i could to work the fucker outta there, but i ended up dropping my subframe and just propping up the engine to get it out... (didn't have to unbolt the motor mounts b/c they were already busted)Comment
All back togther. I left for work on saturday and when i got back it was done. My dad got out and started working on it. Apparantly to do it you have to drop the steering rack, then get it low enough to take the oil pump off. I hear the pump is very difficult to remove. It was a chore, but it is taken care of.Old and improved:
Wow... that actually seems like a bit more work. If I wasnt taking the tranny and clutch out, i might have tried that, but we spent awhile doing that, figuring the pan would be a 2 hour job. I will keep that in mind as an alternative though. Its all back together, got it out today and drove it.
I replaced the center support bearing, rebuilt shifter linkage, replaced tranny fluid, replaced rear main seal, replaced oil pan gasket, and did oil change. should take care of me for awhile.Old and improved:
wow.. that site made it seem alot harder than it is... maybe thats just b/c i had some busted ass motor mounts and a shattered pan... :loco:Comment
