Got my flywheel
  • Chapel
    • 633
    Got my flywheel
    Plus OEM Sachs Clutch kit. :)
    Couldn't find a cheap enough place to lighten AND balance.
    Most places wanted $80 for lightening and another $100 for computer balancing. I also couldn't get a stock 325i flywheel for under $60.
    Got this little beauty for $400. 8lb Turner/JBRacing Flywheel
    BattleWagon|1996 GT Vertigo
  • Chapel
    • 633
    oh, this is also an M3 Flywheel, so it's equipped with the Ignition Trigger... which may or may not come in handy some day...
    • DanGillan
      • Mar 2004
      • 4061
      Re: Got my flywheel
      hey, where'd you get it from
      who hooked you up! ;)
      Dan
      • Chapel
        • 633
        thats weird... I thought I put that in.
        got it at BPG.
        • Bill 84 318i
          • 1600
          That could be a bad thing man.
          Some guy (nitrosomethingorother) got an M3 flywheel by accident and it was "thicker" than a 325i flywheel, and so the throwout bearing couldn't pull away enough. So the clutch was always partially engaged.
          • Chapel
            • 633
            hmm...
            Peter at BPG said it should work...
            I'll call Turner and see if they can measure the width of a 325i Flywheel.
            I know the diameter is the same though and the 325i pressure plate and clutch fit it.
            I'll measure mine too.
            • Bill 84 318i
              • 1600
              Check it:
              • trent
                hmm...
                Why don't you call BPG who sold you the flywheel or just call JB Racing and ask him directly if it will work? Why bother Turner who you didn't spend money with?
                • Jordan
                  • 12913
                  Bill is right, haha.
                  If it took you 13hours to do the timing belt... I estimate no less then 36 hours to do the flywheel.
                  https://mtechniqueabs.com/
                  • LowR3V'in
                    • 4209
                    13 hours?
                    How much does that thing wiegh?
                    • Chapel
                      • 633
                      Because Dougie is my homeboy?
                      • Chapel
                        • 633
                        ha ha... you're a funny fuckin bastard as always.
                        douchebag.
                        This will take me 3 hours max... (helps to work for BMW and Porsche...)
                        unlike the 3 years it took you to get your E30 roadworthy.
                        • Rob
                          • 8166
                          the 'covered wagon' edition shifter
                          BEERTECH
                          • Chapel
                            • 633
                            well, I'll just exchange it rather than going through the trouble of calling people and measuring and shit.
                            If BPG can't exchange it, I can probably get Turner to exchange it... but I bet BPG can exchange it for me.
                            oh, and Bill, thanks for the heads up. You saved me alot of time and frustration.
                            • Chapel
                              • 633
                              BPG will have my new one on Tuesday.
