Guage Cluster Ground Nut
  • Axxe
    • Aug 2004
    • 3355
    Where can I find the guage cluster ground nut? My water temp and fuel guage are all screwy when the car is cold, but fine when it warms up. And this morning my tachometer went on strike. Do I have to remove the guage cluster or can I reach it from the bottom? I don't want to do more work than I need to, I have midterms, and need to study ;) .
    Keep it slideways!!
  • Rob
    • 8166
    I dont think your problem is the ground nuts, if it was, the gauges would be wack with the car warm or cold.
    To get to them anyway, you do need to remove the cluster
    BEERTECH
    • Axxe
      • Aug 2004
      • 3355
      Well, I'm going to attack it first. There is no way that the all three sensors died at once. If it doesn't fix the problem then I'll worry about other things.
      Keep it slideways!!
      • Axxe
        • Aug 2004
        • 3355
        Well, I just pulled out the cluster out, and I found no ground nuts :shock: . Could my cluster be fucked up? Also, things aren't looking good. Some butcher removed the cluster before me and broke left clamp and lost half the screws.
        If the cluster is dead (MotoMeter) can it be swapped for a VDO cluster? I have an extra in the parts car, and everythings works.
        There are two ground nuts, right? On either side (left of blue connector and right of red connector) The bolts were there but no nuts. Or am I mistaken?
        Keep it slideways!!
        • Axxe
          • Aug 2004
          • 3355
          Nobody?
          Keep it slideways!!
          • BS87
            • 1606
            Take the cover off first.
            • Axxe
              • Aug 2004
              • 3355
              It's off now, and?
              Keep it slideways!!
              • LikeCDoos
                • Jan 2004
                • 2522
                replace your SI board or just the batteries on your existing SI board. My cluster had the same symptoms and after i changed the batteries it fixed everything.
                • Axxe
                  • Aug 2004
                  • 3355
                  Sound's like that's what I'm going to do. Had to put the cluster back in, the speedo works and can't get any tickets.
                  Keep it slideways!!
