gas leak fill up
  • NG_White30
    • 43
    gas leak fill up
    so i replaced my fuel pump just recently and doubt it has anything to do with this problem, but recently whenever i fill my car up with gas there is severe leaking out the bottom of the car, driver side, but then when i start the car and drive off the leaking stops....wwwtfff
  • wodcutr
    • Apr 2009
    • 2193
    Did you put a new o ring in when you installed the pump?
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
    • NG_White30
      • 43
      yup
        Pull the rear seat and the access plate(s) for the pump/level sensors and fill the car. If they are the cause of the leak it wll be very obvious. If you have a 318 or early 325i/is/e/es with the 55l tank, you'll only have an access plate on the right side.
        • NG_White30
          • 43
          thanks, i'll have a look before i head to class today.
