Power steering issues
  • craz azn
    • 745
    Hey guys, I've had an ongoing power steering problem for a little more than a year, and I can't seem to find the culprit. Heres what happens, when driving normally, on the street, on track at high speed, etc, its perfectly fine. However, when slaloming back and and forth like at an AutoX, the steering gets so tight that I can barely turn the wheel anymore. I usually have to turn at least half a turn to a turn, and repeat the same motion the other direction immediately for it to start seizing up... Any ideas?
    I've so far changed:
    Steering rack (upgraded to an e36 M3 rack)
    Power steering pump
    Power steering pump pulley
    Belt (twice)
    Power steering fluid canister (changed to an e36 canister, looked the same)
    Flushed the oil at least 4 times in the past year
    I am running e36 tie rods, but that should not make a difference. The only things I could think of would be the universal joint seizing up (was nice and easy to move when the rack was changed) or maybe the lines/restrictor are collapsing/plugged?
    Rippin' Proper | Youtube | Vimeo |
  • emi325i
    • Oct 2006
    • 356
    I had a little bit of oil on the belt that caused the belt to slip and loose power assist randomly. Spray some cleaner on the belt and pulley to make sure it is perfectly clean.
    • Aptyp
      • 6584
      had exact same problem post-e36 rack swap... I had too much PS fluid in.
      • craz azn
        • 745
        Thanks for the suggestion, I will try to siphon some oil out tomorrow and see what it does.
        • Doughnut
          • Oct 2007
          • 869
          What fluid are you using? dextron III?
          ///Monstrosity. (OO≡≡[][]≡≡OO)
          Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
          • craz azn
            • 745
            Yep, ATF.
            I didn't get a chance to take some oil out, going to the racetrack tomorrow. I will try and take some oil on Saturday and update. Thanks so far guys.
