e30 questions
anyone replaced the rear subframe mounts on one before? i read the bently and haynes but didnt see it in there after searching online, i read that im going to need a propane torch , slide hammer and hydraulic press and some other things, is this right? or is it alot easier than it sounds?
and why cant i get my steering wheel off did it exactly as the bentley book said but it wont come off , i need to replace my dimmer/directionals but cant get the steering wheel off, im guessing i need to use a puller?
and my tachometer/mpg guage underneath it/radio/interior lights all didnt come on last time i started it, but i havnet messed with any wiring,
but
when i took the interior light out of the socket in the trunk to put in a new bulb,
when i was sliding it back in, a piece of the metal on the light assembly touched the metal of the trunk and had a small spark. im thinking that caused it, but i checked all the fuses underneath the hood right beside the driverside windsheild but they all came out good?
im so lost
but
im so lost
