Vibration....
  • RobE30
    • 959
    Vibration....
    When Im driving btwn 40 and 50ish (it's worst in 4th gear) there is a vibration that seems to be coming fromt he rear of the car. I replaced the guibo and center support not too long ago. When I re-did my rear subframe bushings the rear u-joint seemed a little "tight" but moved ok. If the u-joint is shot what are my options?
    09 BMW 328xi touring 6spd
    05 Subaru Outback XT 5spd
    87 BMW 325is
    a few bicycles
  • Leaf
    • Apr 2009
    • 985
    1) Find a shop to pull it, replace it, and re-align it (around $180, you need a special machine to align the shaft after this procedure so unless you have it that opts-out diy).
    2) Replace the whole shaft. A new driveline is pretty nice and you can feel the difference. Bit more pricey (anywhere from 350-700).
