the radiator fan? the one stuck on the engine? You need a thin-ish 32mm wrench to go over that nut on the inside of it between it and the fan clutch itself. Just set it over the nut and give it a couple good smacks and it should loosen up.
the radiator fan? the one stuck on the engine? You need a thin-ish 32mm wrench to go over that nut on the inside of it between it and the fan clutch itself. Just set it over the nut and give it a couple good smacks with a hammer and it should loosen up.
Fixed that for you.
Or, you could buy the special holding tool. It is left hand threads. Turn opposite from normal for loosening.
