trunk lock actuator stuck!
  • MaloventEvil
    • 248
    so i had a problem where my trunk lock was able to lock / unlock all the doors, but was unable to open... so i kicked in the ski hole and had a tiny friend crawl through and undo the part connected to the trunk lid only to find that the actuator is stuck in the "locked" position! i can't for the life of me figure out how to open it to release the piece with the loop that is supposed to connect to the boot lid so i can take out the old actuator and install a new one!
    -aurash
  • scott_is
    • Aug 2007
    • 310
    Just unscrew the lock actuator from the car? I think its two 8mm screw
    that hold the actuator to the car. Then your tiny friend would probably have enough play to wiggle it out. I remember it to be easy to swap but I had my
    trunk opened it was my lock that was stuck in thought.
    I can take a picture if it helps
    Scott
    • MaloventEvil
      • 248
      Originally posted by scott_is
      but I had my
      Thats what i meant. I got the trunk open by unbolting the catch from the decklid. Now the problem is that the luck is stuck closed around the catch, and the button (part i put the key in) fell off of the lock. I think i'm just going to take some bolt cutters and cut the catch off unless someone thinks of something clever. ;)
      • deutschman
        • May 2008
        • 5958
        if you need a new one i have one with all the parts you need to install it.
        • scott_is
          • Aug 2007
          • 310
          I took a picture of the latch so you can see witch part you have to
          move to release the lock. you will need to fab an L shaped tool to get to
          it thought.
          The orange arrow points the part that has to be pushed down to release the
          lock
          Scott
