I know some of the ETAs came with 2.93 LSDs stock but, i am not sure which one i tried looking under the diff and looking for the S but there was to much dirt and what not and could not wipe it off. i am pretty sure i have a LSD stock 2.93 it feels like it when i do burn outs and what not. does anyone know what year the ETAs came stock with LSDs.
does my 1984 325e have a LSD
Unless someone put it in there, your eta should have a 2.79 open rear. And there is a thin metal tag on the diff cover on the right side that tells you what gears are in it and also if its a limited slip.
1992 BMW 325iC
1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hp -
If you really want to know if your diff is open just jack up a rear tire and try to spin it. If it rotates then you have an open diff, if it doesn't then it is an lsd. The tranny needs to be in neutral of coarse!The difference between porcupines and BMWs is that porcupines have the pricks on the outside!Comment
Originally posted by e30elose the old man bmwcca badge.Comment
i had a 2.79"s" on mine.
actually it feels nice to drive with an LSD, you could spin the wheels so easly.
i am pretty sure my Fail vert has an open diff. i am getting 4.10LSD for it soon.Originally posted by e30elose the old man bmwcca badge.Comment
jack it up and spin both tires, if they both spin in the same direction, you have an LSD.
i did that test while i was getting an oil change, i know for a fact that my current car has an open diff because i only spin one wheel. FML :(Originally posted by e30elose the old man bmwcca badge.Comment
You can buy 3.73lsd pretty cheap. Why don't you just get one of them and wake your car up and leave the welder alone. The 2.79 rear gear is a dog. Welding the rear will make the make it bind going around tight corners.
sigpicComment
he drives an eta.
2.79S is good, if you want to upgrade get a 3.25LSD. great acceleration and very good fuel economy!:pOriginally posted by e30elose the old man bmwcca badge.Comment
