I recently helped a friend transplant a motor into her BMW, and I'm having problems getting the car to start. Its turns over, but we're not getting any spark at the ignition coil, and the injectors are not firing. The engine transplant was from a 1988 eta to a 1982 eta (5 series). Harness, and all electronics were changed at the same time.
Tomorrow, I'll be testing the ecu and making sure that all the wiring is grounded and connected properly. The flywheel position and speed sensors are both fine, the knock sensor is okay, and the ingition coil itself is fine. Anyone have any other ideas on what I should check tomorrow aside from what's already mentioned?
