Strange vibration in rear...
  • dgspikes
    • Mar 2004
    • 179
    Under heavy load sometimes in first but mostly in second.. I'm getting a heavy vibration that feels like its coming from the rear. This usually only happens when I'm going slightly up hill or when there would be more force against the car to get going. *Also, this only happens after you get to the sweet spot a little after 3500 rpms..*
    The vibration feels like I'm going over those bump strips that are put on the road to give you a warning at a pretty rapid speed or when you break loose in the rain and the tires bounce from trying to get traction.. Any ideas or suggestions of what to look for and check? Anyone ever get these same symptoms? Tia- Dan
  • mattdk318i
    • Jun 2006
    • 3953
    Csb
    • mattdk318i
      • Jun 2006
      • 3953
      http://www.pelicanparts.com/bmw/cata...pg3.htm#item20
      • BTP325ic
        • Apr 2009
        • 700
        weld it.
        • dgspikes
          • Mar 2004
          • 179
          Thanks guys.. sounds about right.
