Cleaning Carbon deposites?
  • Brian 89 325i
    • 1450
    Im doing my headgasket right now and I was wondering if i should try to clean some of the carbon off of the pistons? I dont want to eff anything up but there is quite a bit of shit on there.
    Thanks
    Brian
    I usually just scrape it off if there's a thick coating. That's done by bringing a cylinder to TDC, covering the other cylinders and scraping. Then finish with compressed air to blow junk out od the gap between the piston and cylinder. Repeat for each cylinder. If the deposit is thin, just ignore it.
    • Brian 89 325i
      • 1450
      Cool, thanks.
      I ended up doing that anyway.
      Brian
      • bddog
        • 351
        Put a little oil on cylinder walls.Turn over once. The rest of the crap will stick to the top of the cylinder wall. Wipe clean. - Steve
        • e30slut
          • May 2008
          • 793
          i USED A WIRE WHEEL
