Ok as some of you know my automagic 86 528e hasn't started in 2 years. I just checked the wiring today with the volt meter and found this.
Does this all look right? the car cranks but won't start, fuel pump dosn't turn on. ECU checked, new ignition switch, coil, plug rotor, cap, replaced engine harness. If you bridge the fuel pump relay the pumps run, but if you try to start while bridged won't start. bridged the main and fuel pump relays and still just cranks. I just want to make this car start someway or another. Either the right way or force it to start.
ECU Plug Volt Ground Description
Pin #
30 2.98 fuel pump relay control
35 12.5 power input
18 12.5 power input
20 12.5 fuel pump relay control
15 12.5 fuel inj 4,5,6
14 12.5 fuel inj 1,2,3
11 8.2 fuel rate output
1 12.4 timing control
2 grounded closed throttle
5 grounded ground
16 grounded ground
17 grounded ground
19 grounded ground
AT Shifter consule plug to ECU harness
Blue yellow wire 12 volt
OBC plug to ECU harness
Black wire 2.6 V
Green wire 12.4 V
Black/yellow 8.2 V
Green/yellow grounded
Main Relay
Pin #
85 grounded
87 12.4 when relay on
30 12.4
86 12.4
Fuel Pump relay
Pin #
85 12.4 relay on
87 grounded
30 12.4
86 12.4
Unloader Relay
Pin #
85 grounded
87 1.4
30 12.3
86 12.3
Pin #
35 12.5 power input
18 12.5 power input
5 grounded ground
16 grounded ground
17 grounded ground
19 grounded ground
Black wire 2.6 V
Green wire 12.4 V
Black/yellow 8.2 V
Main Relay
Pin #
85 grounded
30 12.4
86 12.4
Fuel Pump relay
Pin #
85 12.4 relay on
87 grounded
30 12.4
86 12.4
Unloader Relay
Pin #
85 grounded
87 1.4
30 12.3
86 12.3
