I was reading an article today here:
One part, it mentions this:
Fuel Characteristics
Low compression engines usually run well on low octane fuel because they have relatively low charge densities and the burn rate within these confines is usually predictable. A low compression engine switched to 118-octane race fuel will always lose power unless the ignition advance is increased to compensate for the slower burn rates. Even then, a low CR engine may lose power with the timing optimized for high-octane fuel.
From that section, what I understand is that running a higher octane fuel in a car with low compression might actually be detrimental to power?
In my country, we only have 97 and 92 octane fuel and 97 is what I typically run in my E30 318i M40, so this bit of reading got me wondering about it as I have never tried the 92 octane before.
