Are the coils from the m10 and the m20 the same?
M10 vs M20 Ignition Coil
trent
Re: M10 vs M20 Ignition Coil
By part # in ETK: NoOriginally posted by kencopperwheatAre the coils from the m10 and the m20 the same? -
ken a coil is a coil, if anything the m20 has a higher output, it should work.Originally posted by kencopperwheatAre the coils from the m10 and the m20 the same?
-camComment
Ken, I think the resistance values are only to tell if the coil is good or bad.
If you want, try the M20 coil, and let us know if it gave you any better performance.
All I can tell you is that my coil was bad this weekend. Got a new one and it started right up.Comment
mcgrath,
Is this a direct replacement coil, or did you have to change wiring around to run it?
I'm interested in doing this.Comment
Awesome! I sent you an email.Originally posted by mcgrathKen, If you need a coil i think i have 2 or 3 from 84 and 85 318i's they mean nothing to me because i use an msd blaster ss coil now and don't need them. If you need a coil i will send you one free of charge.Originally posted by Grueliusand i do not know what bugg brakes are.Comment
I've an M20 coil in my M10 and my car fired up a lil' quicker but I dion't feel much progress in performance :?
1989 E30 318iS
_______________________________1989 E30 325iC M-Technic I
1997 E36 328iT
1990 E30 325iT 24v SOLD
1989 E30 325i 2.7i M-Technic II SOLDComment
no wire hacking required to use the msd blaster ss coil, but i changed my cap and rotor to the one used on a 75 2002 so it doesnt use the resitor type plug wires. then i bought a box of accel high performance wires that you will have to cut to your disired lenght. its very easy and makes a very noticeable difference.Comment
The euro models down here are.
12 13 1 273 216, used in the E30 until 1987.
List of cars it was used in
E12 - 518, 518i,
E21 - 315, 316, 318i, 320i, 323i
E23 - 728i, 728iS
E24 - 628CSi
E28 - 518, 518i, 520i, 525i, 528i
And of course the E30 - 316, 316i, 318i, 320i, 323i.Just a little project im working on
- http://www.lse30.com -Comment
