Running minus the SI board?
  • Ryan Stewart
    I Love Miatas
    • 8978
    Ive got a a euro cluster but the SI board died. I have MY Si board but to be honest its about as annoying as the econometer. I know it can wreak havoc on the cluster but has anyone managed to run the full cluster without it?
    It would be a perfect place for a remote display for my passport. :)
    Im now E30less.
  • Henna Red
    • 188
    ...never heard that it was bad to run without si board... is this euro specific?
    • DSchultz325e
      • Aug 2004
      • 1158
      man my si board hasn't worked ever since i've had the car. if it comes on, it just tells me my car is screwed up and it needs both inspections and an oil service. then after i go over a bump it's gone. i haven't seen any adverse effects without it.
      I retired my E30 for now...
      E46 323i
      David Schultz
      • Ryan Stewart
        I Love Miatas
        • 8978
        Im just wondering if the finctions of the cluster have been affected. I know that when the SI board is on the fritz often it can affect the other functions of the cluster.
        Adam pulled this out and tested it on his Eta so hopefully I can make it run in mine. ITs a VDO board to VDO board.
        Im now E30less.
        • Ryan Stewart
          I Love Miatas
          • 8978
          Worky Worky.
          Now, anyone need some free US spec cluster parts?
          Im now E30less.
          • BMW BMXER
            • 2325
            Free si board? ;)
            Sold it.
            • Ryan Stewart
              I Love Miatas
              • 8978
              Nah I installed mine. You could have the one that is bad and see if there is something off it you can use.
              I have the mainboard (same part # US or euro), Eta tach and econometer, fuel, temp, and the speedo works but one of the ODO gears broke. Then I have the VDO backing and a Motometer front housing.
              A bonus of the european cluster is that the damn foglight logo panel is much thicker so its not so damn bright.
              Im now E30less.
              • LikeCDoos
                • Jan 2004
                • 2522
                will all the functions on the cluster still work w/o a SI board?
                • grlaneriejr
                  • 321
                  do you want to give up the backing for the vdo cluster. is that the tan piece with 2 tabs for screws?
                  • Ryan Stewart
                    I Love Miatas
                    • 8978
                    Dunno, I went ahead and ran my old SI board.
                    I have the tan motherboard that everything connects to and I have the plastic part that sandwiches the motherboard to the front housing.
                    Im now E30less.
                    • BavarianBimmer
                      • 951
                      [quote="Ryan Stewart"]
                      A bonus of the european cluster is that the damn foglight logo panel is much thicker so its not so damn bright.[/quote
                      You're a lucky one, the early ECE clusters have thinner masks hate those too :D
                      1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                      1997 E36 328iT
                      1990 E30 325iT 24v SOLD
                      1989 E30 325i 2.7i M-Technic II SOLD
                      • Ryan Stewart
                        I Love Miatas
                        • 8978
                        you can change that, it just pulls out ofthe side of the cluster face. Then just slide a latter model one in.
                        Im now E30less.
                        • Brew
                          • 3060
                          I don't think so. My SI batteries went on my car and the tach wouldn't work.
                          I would love to figure out a way to completely bypass it, or maybe at least hardwire it instead of using those stupid little batteries.
                          '91 318is
                          • Giorgio
                            • 169
                            Re: Running minus the SI board?
                            you'll be needing that, god i love s50 e30s. :twisted:
                            • E30-323ti
                              • 328
                              I'm not running any SI board at all on my Motometer cluster.
                              All I had to put in was a jumper wire in for the temp gauge.
                              From the 2nd pin to the 5th pin I think it was.
                              292rwhp E30 :D
