Tonight i was driving home, exiting the freeway. Was in 5th, pushed in the clutch pedal. Pedal pressed like normal, then i hear/feel a pop from the clutch pedal, and the pedal presses in a little further.
I can press the pedal in, and i can feel a heavy vibration through the clutch pedal. When i engage a gear, the clutch is disengaged enough to not cause the tranny to grind, but when i start to release the clutch pedal, the car will shudder.
My thoughts are maybe i bent/broke the clutch fork, if there is a clutch fork on the car, maybe the throw out bearing failed, or i popped a band on a pressure plate. Im unsure what the problem is exactly, but im relatively sure its flywheel/pressure plate/clutch related.
Any help or insight is greatly appreciated.
Car: 89 325i
Car: 89 325i
