Sticky Throttle, bad response time...
  • PanamaE30
    • Oct 2004
    • 768
    Another of the great number of ailments my car has right now is the throttle response.. When I step on the gas there's a very noticeable lag before it responds.. and when it does respond it feels like it's surging...
    something i've noticed is that when i step on the pedal, i have to press a certain amount before the engine reacts, but when it reacts it does so a lot more than it should for such little throttle input.
    However, I checked the throttle cable and it's taut and tuned, so I know it's not that. Anyone have any suggestions?
    1988 325iC - "Betty" - Daily Driver/Project Car.
    1993 318i - "The Golden Dream" - Dad's Car.
    1995 318ti - "Hellrot" - R.I.P.
  • UNHCLL
    • 8790
    yea, get used to it.
    its called the AFM.
    It sucks, so its either deal with it, or spend ~700 and get an MAF
    Below the radar...
    • PanamaE30
      • Oct 2004
      • 768
      Don't think it's that...
      this lag is not normal. I've driven M20 powered cars that do not have lag like this.
      I don't know if I'm explaining it right, it's like, should I step on the pedal, there's actually a delay for the engine to actually respond. What you're talking about would be a delay in power to be made.
      it's like this.
      say the throttle body's range of movement is seperated into 10 parts.
      When i step on the throttle, lightly increasing pressure, it feels like it doesn't open up until like 30%.
      So instead of the normal: 1...2...3....4....5.. etc
      it goes like 1..............5...6....7...8...9..
      it's the same way on deacceleration. There's a point when i'm letting off the gas where the car just simply disengages; and my foot is still pushing down significantly.
      • cheades
        • 632
        Try putting lube on the cable and pump the throttle a bunch to get the oil worked into the throttle cable, might help to loosen it up and make it work better. The other option would be buying a new cable, also check to make sure the throttle body works smoothly as it may be the part that is sticking.
        • M-technik-3
          • 18946
          Clean the inside of your throttle body out.
