Penetrating Oil Test
  • AndrewBird
    The Mad Scientist
    • 11898
    This was posted on another forum I frequent. Thought it was some useful information, so I decided to post it here.
    Machinist's Workshop magazine tested penetrants for break out torque on rusted nuts. They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment. The results are as follows;
    Penetrating oil..... Average load
    None ..................516 pounds
    WD-40 ................238 pounds
    PB Blaster ............214 pounds
    Liquid Wrench ..... 127 pounds
    Kano Kroil ............106 pounds
    ATF-Acetone mix....53 pounds
    The ATF-Acetone mix was a "home brew" mix of 50-50 automatic transmission fluid and acetone.
  • wodcutr
    • Apr 2009
    • 2193
    Very interesting. Where would one aquire the acetone?
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
    • Thor
      • Jan 2008
      • 31
      You can buy acetone at Lowe's or Home Depot. It is usually near the paint thinner.
      • SpecM
        • Oct 2005
        • 4531
        Advance Auto and Sherwin-Williams carry it too
        1989 cirrisblau-metallic 325i
        • whiltebeitel
          • Apr 2007
          • 2098
          Thank you so much in advance for this!
          '89 325i track sloot
          '01 530i daily
          -Enginerd
          • Gooch
            • Dec 2006
            • 1674
            I'm going to have to try the Acetone-ATF mix. Thanks!
            '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
            '87 535i - Vacuum brake conversion [SOLD]
            '93 525iT - 5-speed swap - 320k and counting
            '09 328xi - 6-speed
            • allwheeldrive
              • Jan 2008
              • 272
              Interesting. This could come in handy living in Ohio.
              • george graves
                • 20003
                I usually have both of those around - nice tip!
                Originally posted by Matt-B
                • txtorquemade
                  • 1758
                  Wow...great info. Thanks
                  sigpic 1987 325is
                  • M-technik-3
                    • 18946
                    Interesting, I like PB blaster it works fast and I tend not to strip nasty cruddy rusted on stuff.
                    • Philo
                      Ich esse kleine Kinder
                      • 3334
                      Good info. One pat on the back awarded to you!
                      -tim
                      Originally posted by Jordan
                      I like the stance
                      • StereoInstaller1
                        GAS
                        • 22679
                        No shit, what a trip.
                        Somewhere in my pile of shop crap I have one of those metal oil cans that squirts...or maybe I did, or something. That would be a great way to use it!
                        Thanks, bubba!
                        Luke
                        Closing SOON!
                        Thanks for 10 years of fun!
                        • AlarmedBread
                          • Sep 2006
                          • 1510
                          Straight ATF works pretty good too, if your car has a very leaky PS rack it will be very easy to work on after you pressure wash the underside. :)
                          • gearheadE30
                            • Jun 2007
                            • 3734
                            Huh, I'll have to try the acetone-ATF mix...
                            Project M42 Turbo
                            • 3bvert
                              • 1032
                              yes it works, tried it, had a way frozen bolt, thought I would try the "mix" and if it did not work, I had my trusty pb blaster to fall back on
                              well, did not need the pb blaster
                              also straight atf does wonders for sticky rings, squirt it the cyllinder ( on m42 dngine on its side takes a lot), let it soak a day or two, blow it out ( crank engine a shit load with no plugs in it, if you leave the plugs in, could build rpessure you dont want result of). recheck your compression
                              change engine oil, as the atf will have leaked by and into the crank case. I learned this working on a motorcycle that was frozen solid, then again on a car that had low compression. then again, with my m42, wiht the head off, I soaked all the cylinders wiht it for a few days while head was at machine shop
