Turn signal won't disengage
  • n2motorsports
    • Jun 2007
    • 173
    this weekend i pulled my cluster to fix the odometer. everything went smooth, but now whenever i engage the turn signal, both left or right, it won't disengage by itself after i've made the turn. in addition, im smelling a plastic burning smell through the far left vent now.
    anyone else experience this? did i short something while jamming all those wiring harnesses back into the dash? on the positive side, my speedometer decided to work full time again. :D
  • DynoTechMotorsports
    • Jun 2008
    • 116
    did you take your steering wheel off?
    James Burger
    DynotechMotorsports
    • n2motorsports
      • Jun 2007
      • 173
      yes i did, that cluster is impossible to remove otherwise.
      also, i marked the spline when i removed it but i wonder if i over torque that 22mm nut b/c my wheel is kinked.
