I would start with the checking out the main relay then the fuel pump relay. I would start the car and let it idle, pop the hood and smack the the relays lightly and see if it cuts out or off. If no faults there are found I would then look for a loose ground. I would also check out the condition of the fuel pump as well possibly shutting down when it heats up?...
