Dumb Question here
  • Rami
    • May 2008
    • 70
    Dumb Question here
    I tried searching for the answer of my question on here and on google, and I couldn't find a straight answer. I am wondering would M3 springs work on my 87 IS, do I need anything to make them work (different shocks?) and what are the pros and cons of installing those springs, also when installing M3 offset control arm brackets does the ensuing alignment require different specs or are the 325is specs used ?
    1987 325is
    1985 735i "frankie"
    1996 Infinite Q45t
    " I do appreciate you being here, you are usually so mired in sleaze, it must have been an effort to come down to the stuido" fox anchor on the simpsons
  • Liam
    • 753
    They will fit without any trouble, just a tad lower.
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
