Fan hitting coolant hose
  • UDM Motorsport
    • 169
    hi gruppe
    i have a 87is.
    well last month, one of the coolant hose busted - the one that comes out of the thermostat and curve's around the cap/rotor.
    turns out the fan was very slightly hitting the hose, thus a hole.
    When car not running or idle, the fan doesnt hit the hose.
    So i replaced the hose, trim the ends of the fan so the distance between hose and fan is further.
    Well i checked today and seems the hose is wearing down again.
    Any ideas???
    Car is on stock motor mounts. I ordered the IE poly motor and tranny mounts.
    Will that fix the issue?
    What are my options to fix this problem?
    i'm close to removing the fan/clutch completely and going with an electric fan.
    thanks
    franklin
  • Rigmaster
    • 3464
    Re: Fan hitting coolant hose
    Short answer= you probably have broken motor mounts.
    You can replace them with stock and it will be OK for a while, many years if you don't track/autox the car. You can use the 5/6/7 series mounts as a cheap upgrade- they are a little stronger than stock E30 mounts- I put these in my car a couple of years ago, and they are still good.
    Urethane mounts will cure the problem too, but will probably transmit more vibration to other parts of the car.
    Bret.
    Originally posted by UDM Motorsport
    hi gruppe
    i have a 87is.
    Any ideas???
    thanks
    franklin
    • Fred
      • 659
      Just zip-tie the hose back to the hole that you use to lift the engine. Problem solved.
      '86 325 2.8i stroker - Arctic Blue
      '11 328i Sports Wagon - LeMans Blue
      Strictly Eta
      • Matto
        • Jan 2004
        • 800
        Exactly how my hoses are saved from the fan.
        • clavinZERO
          Hella sick E30
          • Mar 2004
          • 2027
          sometimes the zip-tie method still isn't enough, but a good quick fix nonetheless.
          "BMW Style 32 Poster-Child"
          HTTP://WWW.CLAVINZERO.COM/e30-5-lug
          **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
          • el_4ever
            • 145
            make sure the hose is positioned correctly...since it connects at the top and the bottom, you can twist it to fit....in other words you probablly have it installed twisted. that's what had happened to me any way when it was rubbinh against the alternator.
              • 37828
              Yes, most likely the motor mounts, happened to a friend. My hose is zip tied just like Fred said.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • UDM Motorsport
                • 169
                thanks for all the help.
                i swapped out hoses...got a spare one just in case...but not driving the car until i get the motor/tranny mounts from IE.
                another question, how hard is it to swap motor mounts?
                Tranny mounts shouldnt be a problem.
                thanks
                franklin
