Anyone know if 323i injectors are high or low impedence or know the flow rates on them? If you do thanks.
323i Injector question
mine are high impedance, i think they flow 13lb/hr - not sure what fuel pressure they run though, the most reliable source i have says 2.5bar but other surces say 3 bar... i'll be sticking a 3bar regulator on mine very soon so i should be able to tell if it makes a difference ;) -
it is 3 bar, jetronic uses higher system fuel pressures. Not as bad as K-jet though, ive seen over 4 and a half bar of pressure at injectors on k-jet cars :oJust a little project im working on
- http://www.lse30.com -Comment
