My girlfriends car died on the way to her work this morning :(
It died while running, engine stopped, all the dash lights came on, stereo stayed on.
When I went to go pick her up we tried to start it but it just made a loud whirring sound about where the starter is located.
I don't think the motor was turning over.
She was running late so I didn't get a chance to do any troubleshooting, what do you guys think I should check first?
Any other ideas of easy stuff to check while im there?
I did a bit of searching and it seems like the main relay or the alternator might be the problem.
The starter doesn't sound like it's operating correctly but I don't imagine a fubared starter would stop the motor from running... Although the starter has gotten stuck on before due to a faulty ignition switch that doesn't always return to the correct position after starting. Maybe it got stuck? I have no idea.
The car in question is an 1989 325ic and mine is a 1987 325is, so i have some parts available for a quick swap.
I have a multimeter at work so I can do some electrical testing as well.
Thanks in advance for your help!
