Crank Window Conversion???
    what is required to convert my windows to crank windows? I have the door cards off now and would like to eliminate some wires and some weight...
    My LS1 swap thread:
    http://www.r3vlimited.com/board/showthread.php?t=160030
    I just sold a set. You will need the crank assemblys and windows
      so i would need new windows too? I cant find a part # on realoem.
      Just curious, what did you sell your set for??
      My LS1 swap thread:
        75 shipped, Which i thought was a decent deal. The only reason you will need new windows is for the bolts.
        The crank setup utilizes bolts to attach the window. Im sure you could drill and tap your old ones if you were creative.
