Car heating up?
  • e30Matt
    • 5077
    Car heating up?
    My other car ('89 325iA) has some strange problems.
    The first thing I noticed is that the heat goes cold as soon as I stop and the engine returns to idle.
    And now, when sitting still at a light in Drive, it begins to heat up, and it appears to want to continue climbing past the 3/4 mark, but as soon as it climbs past the 1/2 mark I either shut it off, or do what I've found cures the problem: put it in neutral and bring the engine revs up until it cools back off.
    I was driving back from class today and noticed that if I turn the A/C on (kicking on the aux fan) as well as turning the heat on full blast it will about one time out of five cause it to cool back down while rolling.
    I added a mixture of 75% antifreeze/coolant and 25% water to it a few days ago, as I was headed up to the mountains and didn't want anything bad happening, and I didn't know the current mixture.
    There is a sweet smell when I turn the heat on full blast, but I've looked all over inside for coolant leaks and haven't found any. I figure if the heater core were leaking, I'd know it by now. Any ideas?
  • Jonathan M3
    • 1837
    Have you checked the fan clutch?
    '05 E46 M3 Imolarot/Cinnamon - CURRENT
    '98 E36 M3 Estorilblau/Dove - SOLD
    '90 E30 M3 Brilliantrot/Black - SOLD
    SRS BSNS Motorsports - 24hrs of LeMons Racer
    • e30Matt
      • 5077
      Not yet, I haven't had a chance to get under the hood. I'll give it the rolled up newspaper test.
      EDIT: Walked out to the car, there was a fairly good sized puddle (5-6") underneath the plastic undertray beneath the engine. It's dark now, but I may be able to get out and take a look at it... anyone have any clues?
      • bddog
        • 351
        Your obviously heating up from loss of coolant.Hope for a hose problem, but water pumps often leak when they go bad. Fix before a small problem causes a large one from overheating. Good luck. Steve
        • e30Matt
          • 5077
          But i'm still within the tolerances as far as coolant level is concerned... would the leak still cause a car with plenty of coolant in it to overheat?
          • mikeedler
            • 6707
            did you bleed out the cooling system, it could have some air in it, and that would cause it to puke up some fluid. bleed it out.
            • trashcop 80s 80s
              • Jun 2004
              • 1130
              My water pump started leaking about a week before it went out. Do you know when the last time it was changed?
              • mph
                • Jan 2004
                • 536
                I would say its your water pump. My 325ic didn't leak when the water pump went bad. The temp gauge would climb when I was stopped and the heat would stop blowing cold.
                I also replaced the thermostat at the sametime. It was under $80 to do it all (no including the coolant though), parts from dealer.
                Current BMW's:
                2004 330Ci
                1986 European 325i cabrio
                1986 735i
                Previous BMW's:
                1989 325is RIP
                1989 325iX RIP
                2001 740iL RIP
