Cleaning grounds
  • shields
    • Sep 2004
    • 46
    Cleaning grounds
    Where are the 5 or 6 main ground points that need cleaning and/or tightening once in a while?
  • E30/M30
    • 224
    The one's i know of are,
    battery earth terminal
    battery earth lead to chassis
    engine earth cable
    driver's side (US) behind the dash,several brown wire's with ring terminal's held in place with a 8mm or 10mm(?) nut
    fuse box earth,hinden from view under one of the relay's there's an allen bolt that secure's an earth terminal inside the fuse box
    There's probobly more than that
