Best engine rebuild book(s)?
    I'm starting to piece together the turbo project for the S52. A lot of people tell me that with a good headgasket and ARP studs it will reliably sustain the boost level I want. But I know the right way is a piston/rod swap. This means pulling the engine and basically doing a rebuild.
    I've never done this before but with this car being what it is to me, other than having the block and head machined, it's either I do it myself or I don't do it. This project is taunting me, saying "HAAHAA, you coward, you will never attempt this". So of course I want to. Can you guys recommend a good book to study on how to do these things right? More than one book is fine, I'll read it all. There probably isn't one but if there's a good M5x specific rebuild reference too, that'd be bonus.
    Thanks,
    D
    The "right" way??
    How much power are we talking here. What cams? What kind of lift? Static CR? Boost Levels? Methanol?
    Past Car : E30 S50 6 Speed 5 Lug 3.73
    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
    ___________________________________________
    BNB Designs
    Engine Swaps, Fabrication, Innovation, General Repair
    Richmond CA
    Julian 848-248-8029
      Check Bimmerforum's FI section.
        Best book that I've found is http://search.barnesandnoble.com/The...089268/?itm=28
        It's aimed toward v8 crowd, but covers a lot of info. Barnes&Nobles usually has it on the shelf.
          I'm looking for 450-500 at the wheels. Right now the plan is to just put in a .140 MLS hg and ARP studs. But VAC's turbo build kit looks very appealing (so 8.5 CR). Cams will be stock. Pump gas.
          Thanks! I'll check it out.
            Its not a rebuild book, but check out Maximum Boost by Corky Bell. Really great book about...you guessed it.
              I have this book it is worth every dollar. I have read alot of stuff but this book is best with good pics and shows you how to tell if a mechine shop has done a good job or not. Highly recommened.
