I put on my right turn signal and it blinks really fast. I check all of the lights on the right side of the car expecting one of them to be out. None of them are out. Both headlights, the foglight, front and rear turn signals and parking lights all work, and the brake lights work great too. What could possibly be causing this?
Crazy Turn signal Need Help
its a ground problem e30's had with the front bumber, i can't exactly remeber where or what you had to do...could someone else sum this up for me???
-cam -
Last edited by ///M42 sport; 04-30-2011, 03:20 PM.Renting my rear wheel bearing tool kit. SIR
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Which fuse would be out? All of the lights in the car work fine. Just the right turn signals both blink really fast.
As far as the grounding goes, would it be behind the signal housing somewhere?Originally posted by Grueliusand i do not know what bugg brakes are.Comment
My turnsignals went completely out about two months ago and I checked the bulbs, replaced fuses and still blinky no worky. So I opened up the steering column and inside there is a small black box about 1" x 1" that connects to the blinker lever itself. Mine was burned out, so I replaced it and they work perfectly now. You might want to check that to see if somepart of it is out which might cause the sparatic blinking. It's worth a shot, its only 10 bucks to replace it.
-GaryEstoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
